10-08-2025
06:35 PM
10-08-2025
07:06 PM
Dunkman
Hello, I just help my friend with this situation
My friend activated account on October 1st and transfer her old number to public, she received the message from old account and replied with Y, everything went fine but now that number is seem off cause we make a call its went direct to voice mail, what can she do now? Her account number is 1000000xxxxxxxxxxx thank you
Edit by Dunkman: removed personal information
10-09-2025 02:02 PM
Just wondering if they respond yet thank you
10-08-2025 07:19 PM
Ok I'll wait for you thank you
10-08-2025 07:11 PM
Likely a porting issues. I will private message you the Telus team porting phone number. They can check if your porting was successful. Check your private message inbox.
10-08-2025 07:07 PM
As it now appeared in the account is total different phone number, and old Sim did remove couple days ago
10-08-2025 07:05 PM
Try to remove the old Roger's SIM card from phone. Then make PM eSIM the primary SIM card.
Might need to reboot aftewards.
10-08-2025 06:41 PM
She reply Y right away and old sim still in the phone because she activated Esim on public mobile and the number she port its from rogers company
10-08-2025 06:37 PM
did she reply YES within the 90 minutes...not just Y.
Did she remove old sim and install new Public Mobile sim ?
