10-09-2025 12:33 PM
10-09-2025 02:09 PM
@will13am wrote:@Bbuck , you can check whether your phone is VoLTE compatible with this checker.
https://www.publicmobile.ca/en/get-help/articles/volte
You can verify VoLTE functionality on your phone by dialing *#*#4336#*#* to bring up a hidden menu, select phone information then IMS service status. If you see VoLTE as available, it should be working for you. If VoLTE is not available, you can maybe consider this hack. All my devices are VoLTE compliant so I have not had to use this hack, so I can't offer any personal comments.https://www.reddit.com/r/FidoMobile/comments/1jvlvch/force_enable_volte_on_unsupported_carriers/
First check brought this
As I strongly suspected PROVIDER decides which phone to activate VoLTE even if your phone DOES support VoLTE.
That code *# etc. did not bring any 'hidden menu' on my S10.
10-09-2025 12:43 PM - edited 10-09-2025 12:45 PM
10-09-2025 12:43 PM
What's the point of the of the site telling me it's volte compatible then? Where is the definitive Whitelist?
10-09-2025 12:35 PM
Phone Might be VoLTE compatible but if provider does not enable it you will not see that option.
My Samsung S10 IS VoLTE compatible but since it is 'old' I do not see that option.
