08-22-2023
06:16 PM
08-22-2023
07:22 PM
computergeek541
Need help to get an email to allow port-in to Public Mobile
I switched from Virgin earlier today. Still having trouble getting incoming SMS and incoming voice calls.
Virgin said they still have my number and I need to ask Public Mobile to send me an email that I can approve for the port out from Virgin to port in Public Mobile.
I will have lots of issues accessing MFA apps and websites in the meantime.
Place email me asap - SMS and Voice don’t work.
thanks
08-22-2023 11:05 PM
Many thanks @LitlLdy
Hope you feel better soon
08-22-2023 11:02 PM
@Promet wrote:Op did not delete the Virgin eSIM on the iPhone. I learnt after the fact that I could have gone into setting > cellular data to turn on the Virgin eSIM (which will turn off the PM eSIM) to approve the text message with the Virgin eSIM.
It appeared that before the Virgin line turned SOS during the actual port-out, the Virgin eSIM remained active receiving incoming/outcoming calls and texts as well as had data services; at the same time that the PM eSIM when turned on would have data services, outcoming texts and calls.
@Promet , that’s why I was asking those questions, I could have told you 😞 . I’m really sick right now but kept looking for your reply! I’m sorry you went through all that. I had no way to tell you to save you all the trouble 😞. I’m happy it worked out for you & I’m really proud of you for not giving up.
08-22-2023 10:57 PM
08-22-2023 10:47 PM
Thank you everyone @LitlLdy @Handy1 @hTideGnow @Chalupa_Batman for your support! My port-out has now been completed and I’m able to receive incoming calls and texts about one hour after PM finalized and confirmed that Virgin cleared the porting.
The PM porting team was very helpful. After re-initiating the request, I spent over an hour with Virgin to manually complete the approval. Even after that, the port out was unsuccessful because there was a Virgin account number issue which the PM team was able to fix for me as the PM team retried and finalized the process with me over my second PM team phone call.
What I didn’t know until everything was completed that may be helpful if I had to do this again:
- Even though iPhone 12 can only use one active eSIM at any given time, the phone can store multiple eSIMs until the user deletes them. In my case, the PM eSIM provisioning did not delete my Virgin eSIM. I could have turned back on the Virgin eSIM to receive SMS which would have included the text requiring me to respond with YES within the 90-minute transfer time window using the Virgin eSIM. What I did was responding YES to the Virgin short code SMS with my active PM eSIM so the YES respond did not get back to Virgin. This seems to be the step that could have saved me from having to spend hours with Virgin to process the manual port out approval.
08-22-2023 06:43 PM - edited 08-22-2023 06:44 PM
@Handy1 wrote:@Promet There’s a number for live support that can re trigger the port request will send you it private message as we not allowed to post it here . And get it fixed
@Handy1 , it was already sent by @hTideGnow in the 1st message on this post!
We’re trying to find out if Op deleted the Virgin eSIM from iPhone, if so can not receive the text from them to approve the port over to Public Mobile!
08-22-2023 06:41 PM - edited 08-22-2023 06:41 PM
@Promet wrote:I was on Virgin eSIM so I need PM to initiate the process by email according to Virgin because I only have PM eSIM now
@Promet , did you delete your Virgin eSIM from your iPhone or is it still on your iPhone? The Virgin eSIM needs to still be on (enabled) your iPhone in order to receive the text to approve the port request from Virgin!
08-22-2023 06:27 PM
08-22-2023 06:26 PM
HI @Promet then make sure Virgin eSIM is enabled and able to receive text. Do not delete the eSIM until you are sure the porting completed
08-22-2023 06:23 PM
08-22-2023 06:22 PM
I was on Virgin eSIM and now on PM eSIM.
it’s iPhone 12 so only one eSIM
Virgin can confirm they still have my number because the request expired
08-22-2023 06:21 PM
Hi @Promet
call the PM porting team.
Again, make sure your Virgin sim is there so you can receive the text
and do not close your Virgin account. Once porting is done, the account will be closed
08-22-2023 06:20 PM
I guess @hTideGnow will send you the number via PM. Please put your VM SIM card back in. Then wait for the text again. Then leave your SIM in until you see the Virgin name disappear of the top of the screen. Then try making a call. If you can't, the port is complete. If you can, still an issue.
08-22-2023 06:20 PM
Yes, please send me the number. I can still dial out from the phone. Thanks
08-22-2023 06:19 PM
I did. And they said they never received my Yes hence I have to ask PM to reinitiate.
08-22-2023 06:18 PM
Hi @Promet
Did you receive a text message from VM and say YES?>
08-22-2023 06:18 PM
HI @Promet
I will send you a number to call PM porting team, and they can reinitiate the porting request
