03-09-2024 10:22 PM
For the past three. months I am getting very poor signals on my iPhone 8 Plus, only one bar. Sometimes the other party can't hear my voice at all. Why is this happening?
03-17-2024 05:58 PM
Rogers seem to have much signal here. Has Telus downgraded their network?
03-17-2024 05:56 PM
Still only have one bar.
03-10-2024 06:15 PM
Hi, there is no way I can change it to 3G, I can't it anywhere in network setting.
03-10-2024 06:11 PM
I did reboot but same poor signal with one bar.
03-09-2024 10:48 PM
Have you tried to reboot your phone?
03-09-2024 10:33 PM
it could be a problem with the VoLTE. I doubt you can do that, but check the network mode and see if you can change it to 3G and test some calls and see if it is any better
Try your sim card in another phone if possible This can force a sim reprovision, it might or might not help, try it
