07-15-2023
07:27 PM
07-15-2023
07:30 PM
computergeek541
Ever since I switched to the $39/month 20GB plan I find that my call quality has gone down.
When receiving calls, after answering I am not able to hear the person and they are not able to hear me. After ending the call and calling back, this seems to fix it but the initial call is always an issue. During calls, there are also times where the person on the other end will cut in and out. Most of the time I have 2-4 bars of reception so I am not sure why the quality has been poor lately.
Does anyone else have this issue? Any solutions?
07-16-2023 01:36 AM
You can try calling the Toronto & Victoria "test call" numbers listed here:
https://thetestcall.blogspot.com/
There's various options to record & playback, as well as a realtime echo test. Test calling this with 4G/VoLTE if it's currently enabled on your phone, and then by disabling LTE and trying again with 3G. Also test calling with your SIM in another phone and from different locations, as I see others have already suggested.
Can you confirm if you are currently on VoLTE? (ie - does your phone remain on LTE while on a voice call?) And do you recall if you were enabled for VoLTE before the plan change? Just in case the plan change somehow triggered some kind of reprovisioning of VoLTE and either enabled it or disabled it, opposite of what you had before...
07-15-2023 07:53 PM - edited 07-15-2023 07:56 PM
@LMelchi the change to your plan should not matter, probably just a coincidence
If you have not tried yet:
iPhone: Likely no extra work need to do as Telus will enable by default but hide the option. Still you can check
Settings->Cellular->Cellular Data Options->Voice & Data, enable 4G or LTE there
Pixel: Likely no extra work need to do as Telus will enable by default but hide the option. Still you can check
Settings->Network and Internet->Internet, click on the settings icon besides SIM 1, turn on 4G calling there
Samsung/ Other Android: Settings->Connection->Mobile Data, enable VoLTE there
Now, turn off Wifi first. Check if the phone status bar showing it is connected to 4G or LTE
Then make some calls, see if the signal indicator shows LTE or drop back to H or 3G while you are on the calls. If it stays with LTE, then yes, you are using VoLTE, and you can see if calls are any better.
07-15-2023 07:49 PM
@LMelchi Can you try your SIM card in another phone and see if it improves .
07-15-2023 07:47 PM
It happens with more than one person and when I receive calls from both cellular and home phone. For the most part, calls are from people that live in the same city.
07-15-2023 07:40 PM
@LMelchi Try the phone on different networks 3G /5G and see if that helps with voice assuming you have it in 4G /LTE . Play around with it in different areas and test
07-15-2023 07:39 PM
does it always seems to be the same person and are either you or they generally in the same location with making or receiving the call?
