Plan switch and refund?
SLynch
My original plan renewed on June 3, and on June 6 I switched to a new subscription. Does this mean I automatically lose out on the approximately 50 dollars that I just paid? 😭😭😭
SLynch
No I did not see a red banner, otherwise I would not have proceeded
HALIMACS
Yes @SLynch , that's what it means.
When you were doing an immediate plan change (presuming you didn't schedule it for the NEXT renewal), did you not receive a large, red banner notification about the disadvantages of doing an immediate plan change before the last click?
DennyCrane
When you changed your plan you had 2 options:
1) Immediate plan change
2) Scheduled plan change at next renewal
It's generally advisable to go with option 2 unless you're already out of data. If you go with option 1 there is no prorated credit applied. You could try your luck with PM support, but there's no guarantee.
@SLynch   PM is a prepaid provider.  Usually if it is the same day, support could be able to do something.  But the change was 3 days apart, will see if support willing to help.  Please message support directly and ask, hope for the best:
