Plan questions
Markymark1
If I am in Canada, can I make free calls to the United States?
if i am in USA, can i make free calls within the US and back to Canada?  
How much of my 50 gb data can I use in the USA?
@Markymark1 Yes. The Canada-US plan allows you to call US and Canada from Canada and US
and no max data limit for roaming data.  You can use them all in US if you like
fixin1
@Markymark1 - Here is the answer to your questions:
  1. If I am in Canada, can I make free calls to the United States? Yes, you have unlimited minutes to call to American numbers!
  2. if i am in USA, can i make free calls within the US and back to Canada? Yes, you will be able to make calls to Canada & the USA numbers while roaming inside of the states.
  3. How much of my 50 gb data can I use in the USA? There will be one bucket in both Canada and the states, so if you have 0GB used - you have 50GB remaining in Canada and the states. You basically have 50GB in both countries as one data bucket.
Chrissyrioux12
Should work for all the above and 50 gigs
