12-22-2024 10:48 AM
Hello
I would like to change my plan to 75gb/5g/1000 mins intl call for 35$/Month.
It says for new activation only but can you please assist me to have this better plan?
thanks
Noel
12-22-2024 09:51 PM
@buknoy wrote:Thank you all for the reply.. i have the 120$ / 3 months plan.
Customers should be able to downgrade as financial situation changes. I will try to contact cs and also raise this issue with crtc
do you know Canada is a free market? How can Canadian force how free market run the business?
12-22-2024 09:40 PM
@HALIMACS wrote:CCTS , not CTRC, @buknoy
Neither will be of much benefit - they won’t have the discretion to force a different result.
You’re better off asking Public Mobile nicely.
Not much benefit? It will be of no benefit. They won't make Public Mobile do anything and Public Mobiel doesn't have to offer any plan or offer service to anyone they choose not to.
12-22-2024 07:28 PM
12-22-2024 06:01 PM
12-22-2024 10:53 AM - edited 12-22-2024 10:54 AM
@buknoy It’s harder to downgrade plan price these days and we can in my change to the plan that are available o us in our accounts to change to despite what it says on website . One work around might be if you see the $30 plan in your account change to it immediately then the $35 roaming plan should appear then make plan change to it for next renewal . If not only other way is to port number out and back in on newly created account with new sim and new email with desired plan
12-22-2024 10:53 AM
Likely not available to you, however you can try your luck with the Customer Support agents who are employees of Public Mobile.
We're just other customers like you on this forum.
12-22-2024 10:52 AM
@buknoy You can only change your plan to the ones showing available in you PM app. They have made it very difficult to get a cheaper plan. I assume your current plan is more than $35?
12-22-2024 10:52 AM
you can only change to plans that's shown in your account. If you currently have a plan of higher value than this one...you likely won't be able to downgrade to this plan. You can ask though. Use the Chat Bubble or this link ...
