12-01-2018 08:11 PM - edited 01-05-2022 02:40 AM
Hey Guys,
I´ve been with Public Mobile for 40 months and until now I had no issues. I´ve had a plan with text, calls and 4.5 GB of data. After my plan expired this month I changed my plan to a cheaper one and loaded my account with money again. This was possible and the payment for the new plan was successful ($35 instead of 40$ paid from my balance). Unfortunately, even though I now have (paid) a plan with 1GB of data, unlimited calls and text, I can neither call, text or go to the internet (always error message in a browser).
Has anyone experienced this issue before?
Best,
Tim
12-03-2018 06:15 PM
@tspielmann wrote:Hey Guys,
after the trick you proposed data started working again. However, I still cannot call 888 numbers even though I have a Canada wide talk option included. Has anyone experienced this before?
Best,
Tim
Glad you got the service working. The 888 number is a provisoning issue which, like others mentioned the MODs area.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
12-02-2018 11:22 AM
@tspielmann wrote:I will, unfortunately I did not even get a reply regarding the first issue to a message 2 days ago. Anyways, thank you guys!
Yeah response times suck. It was looking good about a week ago. But now back to terrible. Maybe all the promos keep them busy.
12-02-2018 11:20 AM
12-02-2018 11:11 AM
@tspielmann wrote:I´ve called the same number 1 weeks ago with my old plan and it worked just fine. I´ve tried the lost/stolen trick again but no effect.
The number is 1-888-426-7826
Worked for me.
I guess you need to talk to the mods.
12-02-2018 11:09 AM
12-02-2018 11:02 AM
Best,
Tim
Of course you need the 1 in front. But also some toll free's are geographically limited.
Are you willing to share the number so others can see if it works for them?
12-02-2018 11:01 AM
Yes, some other customers have brought up the issue.
You might want to try the lost/stolen phone trick again. It worked with another customer yesterday who was try to call 1-888 Purlator phone number and it worked to fix that problem.
Or the other option is to contact moderator to fix issue.
12-02-2018 10:58 AM
Hey Guys,
Best,
Tim
12-01-2018 09:02 PM
Thanks Guys, now it's working again!
12-01-2018 08:18 PM
Best,Tim
Is your account status active?
If yes, your plan change may not be provisioned correctly. Try the lost/stolen phone trick may get your plan features provisioned again.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
If this trick failed to get thing working again, you should send a private message to moderator for help. But the wait is about 48 - 72 hours. Good luck.
12-01-2018 08:16 PM - edited 12-01-2018 08:19 PM
Best,Tim
Hi, try this. This resets the account and quite often fixes this issue.
Login to self serve - Plan & add-ons - Lost/Stolen phone - Suspend service.
Logout and wait a few minutes then login and select found phone.
This will not blacklist your phone.
