10-28-2022 03:55 PM
So I’ve changed my plan to the amazing $40 for 15 GB at 4G speed. 🤩
I did see a confirmation at the time of the change. Is there somewhere I can verify this on my account now? I just want to be sure it’s going to take effect on my renewal date.
Thank you 😊
10-28-2022 04:14 PM
Just refreshed it again and …voila!
10-28-2022 04:08 PM
This view doesn’t show on my iPhone but maybe it will on my Mac. I’m 95% sure everything will work out. It’s just such a good deal I wanted to be sure I wasn’t dreaming.
Thanks
10-28-2022 04:05 PM
If you changed plan NOW, it should show up on your account.
If you scheduled change on next renewal then wait for renewal date to see if it is changed.
Maybe agent can confirm that for you...
10-28-2022 04:00 PM
Just cross your fingers and hope for the best 😉
That's all you'll get to do until your renewal date rolls around. Good 🤞 luck.
10-28-2022 03:58 PM
@DDM69 I know you used to be able to view any scheduled plan changes on the old self serve account. Do you see further information when selecting Plans/Add-ons about this scheduled change?
10-28-2022 03:57 PM
