02-26-2022 03:27 PM - last edited on 02-26-2022 03:28 PM by CS_Agent
Hi. Can I have the 30 day talk only in $10. As I don’t need data. xxxxxxxxx
Plans
02-26-2022 05:42 PM
You can subscribe to plans PM is currently offering. There is no way to create custom plan; I wish that option existed...
02-26-2022 03:51 PM
Nah man. Unfortunately the lowest priced plan available is the $15 plan w/ unlimited incoming texts, calls, outgoing texts and 100 outgoing minutes. It also includes 250mb of data that can be used for a voip app like textnow or fongo so that you can make calls when not on wifi. While on mobile data they will use approximately 0.5mb/min or 250mb=500min. You can also supplement this plan with the $5/500min Canada wide calling add on which is a one time purchase that does not expire instead it rolls over every 30 days supplementing your outgoing minutes as needed until completely consumed.
02-26-2022 03:49 PM
The only plan is $15/30 days with 100 minute outgoing calls, unlimited incoming calls and unlimited texting.
If you don’t want data, don’t go on AutoPay.
You can go on Shaw Mobile but you need to be on their bundle package.
02-26-2022 03:45 PM
Hi @nahman $15 is the cheapest plan you can get. At least it includes 100 min and unlimited text. Yes, it has data, I know you dont need, but 250Mb is not a lot, you won't know it even exist if you start using 🙂
02-26-2022 03:32 PM
Wow. These CS-Agents are quick sometimes.
There used to be a $10 plan that offered limited minutes and texts. But that was removed a couple years ago. Plans are grandfathered here though so many people still have it. (I have 3)
02-26-2022 03:29 PM
