07-30-2022 10:16 AM
My plan was supposed to be changed today for the 41.25 dollar deal for the 4g network plan.
Please explain even though I changed the plan on the website and it insured me it would be changed on this day, but yet you charged me for my old plan and never completed what was needed on ur end.
Quite upset about this. It not the first time. You inconvenienced me unnecessarily
Service
07-30-2022 10:28 AM
Due to their error, a CSA should be able to manually make the change for your and sort it out so you are on the plan you want.
07-30-2022 10:23 AM
Thank you for the help guys. Take care.
07-30-2022 10:22 AM
Hi @Jason1991 did you schedule the plan change before July 13 for it to change after ? the new My Account portal might have cleared all the scheduled plan change request when they migrated.
open ticket wirh CS Agent and see if they can do anything
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- start by typing : Contact CS Agent
- then Click "Contact Us"
- then Click "Other"
- finally Click "Click here to submit a ticket"
07-30-2022 10:20 AM
The web site recently went through some "upgrades" and seems to have upset some of the processes along the way.
Send a message to CSA, using this link and I'm sure they can straighten out your plan.
07-30-2022 10:19 AM
Did you schedule plan change or you did change plan now?
How far in advance you schedule plan change?
If you believe plan should change as per your expectation but it did not, contact agent for clarification.
And if you do not mind report here what was the issue of plan not changed as expected.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
Watch for envelope in top right corner. It will show Number of unread emails.
