Cannot login, keeps looping
ALH-15
I bought a subscrption plan but i cannot login. It keeps asking to login, then send the 6digit code & keeps repeating. How can I finish setting up my plan?
@ALH-15 wrote:
Its a new phone activation so I dont need to port. Ive also submitted 2 tickets & CS agents are not replying.
I need real help
We're customers here and don't have access to your account.  You'll need to wait for the CS_Agent reply.  Only they can help with this.
ALH-15
I need real help
ALH-15
Yes, numerous times & its the same thing. It never gives me didnt receive code option.
@ALH-15
Did you try login on the PM app on your phone and have the 2FA code sent to your email by clicking on Resend Code/Didn’t Receive Code.
hi @ALH-15 did you ask to port your number into PM? the 6 digits code might have sent to your old carrier sim card if the port is not completed yet
you can also try login using Incognito/private/secret mode on your browser
if same, ask PM support to check.  you can submit  ticket by direct message:
