04-07-2025 04:23 PM
Clarification Required... With the above plan: USA/Canada Specific Example... IF I am in the USA, am I able to MAKE calls and/or texts AND RECEIVE calls and/ or texts from within USA ? and do so without additional roaming fees?...
AND... am I able to MAKE (to Canada) and RECEIVE (from Canada) calls and/or texts? without additional expense.
ALSO... 10GB of Data covers data usage if I am in the USA or Canada?
Under Terms & Conditions, #2 is not clear.
TY
04-08-2025 07:08 AM
@Lu_fr iPhone is capable of volte?
Yes if iPhone 8 or newer and up to date ios. Usually with iPhones VoLTE is enabled by Public Mobile by default and there is no on/off toggle.
04-08-2025 12:46 AM
04-07-2025 10:07 PM
@new-user wrote:Sorry to jump in, just to clarify so the "US Roaming 15 day packages" Add-On is not relevant for can/usa/mex plan since that plan already have the roaming included as part of the plan? (I mean that if I have 20GB can/usa/mex plan , I can also use the data from the same bucket while traveling to US or Mexico with no extra action or fees)
There are no roaming add-ons that work in Mexico.
The plan features of Canada-US-Mexico plans work in all 3 countries.
04-07-2025 09:57 PM
04-07-2025 07:08 PM
TY... my phone is VoLTE enabled... Samsung Galaxy A 22.
Currently buy the 15day US Data/Talk/ plan as needed.
04-07-2025 05:48 PM
@BS09 What phone do you have? It needs to be capable and enabled by Public Mobile for VoLTE to work for voice calls in the USA since they do not have any 3G there since 2022
04-07-2025 04:31 PM
TY
04-07-2025 04:25 PM - edited 04-07-2025 04:26 PM
@BS09 wrote:Clarification Required... With the above plan: USA/Canada Specific Example... IF I am in the USA, am I able to MAKE calls and/or texts AND RECEIVE calls and/ or texts from within USA ? and do so without additional roaming fees?...
Yes, you can send and receivce text messages and make and receive calls while you're in the US without extra charges.
