02-26-2022 10:47 PM - edited 03-06-2022 11:29 AM
- Why does my voucher have 16 digits and you say it should have 12?
Payment
03-06-2022 11:43 AM
03-06-2022 11:25 AM
Yes, thanks for directing my attention to the obvious. The clerk at the store put the voucher under my old carrier and I hadn’t noticed it.
02-26-2022 11:07 PM
HI @Lemongello are those leading zeros? if that , drop them
or try to drop the first 4 or last 4 digits , maybe it will work?
02-26-2022 11:02 PM
Confirm that the voucher is for Public Mobile and not for PC Mobile, Petro-Canada Mobility, etc
02-26-2022 10:57 PM
@Lemongello - Does it say it is for Public Mobile?
If so, look for another series of 12 digits numbers on the voucher.
Please edit your post to remove your email, you may not want to leave personal info. here on the public forum. Click the down arrow at the top right of your post to edit.
02-26-2022 10:57 PM
Please go to the arrow thingy on the right of your post and edit out your email as we don't post personal info on the public forum. Are you sure it's a pm voucher? Where did you purchase it? There are examples of pm vouchers in the voucher catalogue that you can compare....
https://productioncommunity.publicmobile.ca/t5/Get-Support/Voucher-Catalogue/m-p/479165#M343905
02-26-2022 10:55 PM
Where did you get your voucher?
Voucher pin should be just 12 digits Some stores has the actual PIN on the cash register receipt.
