01-27-2024 01:11 AM - last edited on 01-27-2024 10:33 AM by Dunkman
Was trying to port in my Telus number, it’s on a post paid plan and still active. But got this message every time I put the 604 number in. Appreciate your help!
01-27-2024 10:24 AM
Is your original plan with Telus a corporate/employee plan? If so, you will need contact Telus/employer to change to personal plan.
Koodo also has a website to check port eligibility:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
01-27-2024 05:14 AM
The Telus number should port over as PM is under the Telus umbrella.
Are you porting your number on the PM app?
If you are having issues with the porting. DM a CS_Agent to help you complete the porting process at:
Staff hours are 9:00am to 10:00pm EST.
01-27-2024 01:45 AM
@skepticc : Unfortunately all numbers are not eligible to be ported, but maybe the customer service agent might be able to help you. Please direct message them at, https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
