11-19-2024 12:59 PM
11-19-2024 01:03 PM
hi @Guat
if you own the number and the number is currenlty with another carrier, you can request porting in the number as well as the number is a provider now and the account is active
but if you just like the number and you don't own the number now, you cannot choose any number you like . You have to pick from the pool. you can keep refresh and get new numbers and find one you like
