11-22-2024 05:25 PM
Hello, Since i became a public mobile customer (July2024) I have been charged from both my previous provider and public mobile. When i contacted my previous provider they informed me that the number was not ported correctly, and this is an issue on your end.
Please action and confirm refund for services from July-Nov
Thank you
11-22-2024 05:28 PM - edited 11-22-2024 05:29 PM
@Cam2010 wrote:Hello, Since i became a public mobile customer (July2024) I have been charged from both my previous provider and public mobile. When i contacted my previous provider they informed me that the number was not ported correctly, and this is an issue on your end.
Thank you
@Cam2010 You have been paying for two plans since July and never realized it? We are just customers here like you. You will need to contact Customer Service at the link below:
Edit spelling
11-22-2024 05:28 PM
@Cam2010 Not sure it’s anyone fault just need to port number over now or cancel one carrier account or the other but you can ask support what your option may be at this point
submit ticket with support using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
11-22-2024 05:27 PM
HI @Cam2010
PM is a prepaid provider and do not provide refund. Also, since July , were you using your PM phone to make calls and use the data?
you can re-request porting if you like
or if you want to further discuss with PM support , submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
