Phone not sending text but receiving them?
Jennacherice
When I text anyone it’s not giving me an error message telling me it’s not sending but my text aren’t being received by anyone I can only send pictures
18 REPLIES 18
hi @Jennacherice
is it just one number you cannot send to? or multiple ?
is the one that you cannot send a Group Message?
try to directly send to different friends (1-to-1)
and iMessage still turned on?
did you check if Carrier profile is updated?
Sounds like you've got things all under control then, @Jennacherice
Tsawwassen
It's just a setting on your device.
@Jennacherice
While you're waiting for a customer support agent, why not check your device.
A support agent will not be able to give you particulars of the device itself, only the account and SIM.
Jennacherice
I purchased this phone myself definitely not blacklisted never had a problem with text not sending from the moment I put my SIM card in but I did try taking it out and putting it back in
Jennacherice
On it thank you
@Jennacherice
Definitely check SIM cards in other devices and you can also try someone else's SIM card in your device.
Check to see if the device happens to be blacklisted, as I mentioned above with a link to the device checker site.
If it is blacklisted, and it was purchased from an unauthorized/ unknown vendor, your only recourse is to deal with the company who blacklisted it which may be difficult to determine.
Jennacherice
Tried this to no avail
Jennacherice
My plans active until January fourth
Yummy
What phone do you have?
If it is apple, do not use iMessage but native SMS app which uses mobile network and not wifi/data.
Quigley
@Jennacherice
You might want to get help from a Customer Support Agent, so either send a private message to CS_Agent or use the Chat Bot Simon to get a service ticket started.    They can look into your sim card and provisions.
Jennacherice
It happened abruptly during a conversation with someone without an iPhone no change in connections or locations just laying in bed they stopped receiving my text after being able to the entire day then I noticed no one else could receive any actually text aside from iMessage which obviously was still working because I’m connected to wifi I’ve turned my iMessage on and off multiple times and did every other troubleshooting I could think of
@Jennacherice
When you log into your self-serve, or dial *611, what messaging is being given regarding the status of your account?
iMessage will work without cellular service... only needs wi-fi
EDIT:  @Jennacherice    you might also want to try your SIM card in another known working device to see if the services work. If they do, try checking to see if your device happens to be blacklisted:
https://www.devicecheck.ca/check-status-device-canada/
Jennacherice
Sorry I should have mentioned I’ve turned it on and off multiple times this started last night mid texting conversation completely out of nowhere I thought it was my friends phone but they are sending and receiving text fine so I tried to send someone else a sms as opposed to a iMessage to no avail
yackinlyn
sending without data on or wifi to another iphone could be a problem (imessage),
Quigley
@Jennacherice
Turn airplane mode off and turn on data.
Jennacherice
I did this as I am using iPhone I restarted my phone reset network settings turned on airplane mode
Quigley
@Jennacherice
If you're using an iPhone, try turning iMessage off and turn on regular messaging.
Make sure that your data is turned on too.
