Saturday
Hello, Just transferred my number following the instructions. However the port was completed before I got to activating the SIM and now unable to authenticate for full access since it is sending text to the phone number which is technically not even anywhere. Can I please get some help?
Saturday
Thank you
All sorted.
Saturday - last edited Saturday
Hi @MarryTA
Click on "Didn't get code" and there should be an email option to send it to. If you don't see that option, please create a ticket so a CS Agent can help fix it.
If you're still getting errors, please create a ticket.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
