Esim
Carebear12
Saying authentication  unsuccessful  sends cod to a phone number however not getting
2 REPLIES 2
Chalupa_Batman
Hello @Carebear12
You will see the option...  "Didn't get Code"...  click on that. There should be an option to send to your email address. Also, you should go into your phone settings and make sure the Public Mobile eSIM is set as your primary.
If you're still getting errors, please create a ticket.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
slusagm
but does not eSIM setup properly and can make calls, receive calls and send text??
if you requested port, check the old sim card.  If port is not done, the code would be sending to the old sim still.  I learned this the hard way when I joined
