Esim
Jihane777
I’ve installed the eSIM into the phone using the IMEI and to my surprise it went to a different phone , now I have I have 1 phone with 2 numbers, so I deleted the eSIM , and my partner couldn’t have service anymore for days now , I’ve contacted support, while waiting is there anything I can troubleshoot ?
@Jihane777
You will have to wait until a CS_Agent replies back to you in the Message section in your avatar.
hi @Jihane777
you should have kept the esim, then go to the phone 2 to install the PM app and buy esim there first, before deleting the original esim
now with the esim gone, you have to ask PM support agent to help.  You can submit  ticket by direct message:
