I need help, but I can’t submit a ticket
catguy99
Because some of the fields don’t work
So I can’t submit. I already paid for a subscription, but I need to contact for further assistance.
@catguy99
What is the issue that you are having. Sometimes it is quicker on this Community to give you a possible solution.
slusagm
is this how you try to open ticket with Chatbot??
Type the question Submit ticket and select Contact Us to get to ticket open screen
Dunkman
@catguy99
The website has caching issues.  You can clear cache, incognito mode or try a different web browser.
If that still does not work, you can private message CS_Agent.  Supposedly, it does take a bit longer to respond than ticketing.
Send a private message to CSA through the following link :
