Customer service
Rupuzes
How long does it usually take to hear back from a CSA? I am trying to unlock my sim card, I have already sent a ticket. It's been a few hours and it's during business hours.
Rupuzes
Thanks, will give it a go.
NDesai
@Rupuzes Depending on how busy they are, they should get back to you within a day or so.
cc @CS_Agent
hi @Rupuzes
usually within an hour you will get an initial reply and they will start asking you with some verification questions, then another hour after for actual reply.  For most my questions, it is usually all set within like 4 to 6 hours
i suggest you to message them again for update
