12-08-2025
12:45 PM
12-08-2025
05:58 PM
computergeek541
I need to view or change my current mailing address.
There is NO way to do it in the profile section or through eversafe.
Submitting a ticket does NOT work, it leads to 404 or "there was a problem"
12-08-2025 01:26 PM
the address is irrelevant in Public Mobile world. Long as your payment card is valid, that's all that needs attention. Your plan taxes are based on your area code and number ...not your address. For example, if you live in Yahk BC but have an Alberta area code...you only pay 5% GST but no PST.
12-08-2025 12:47 PM - edited 12-08-2025 12:48 PM
hi @chrishm
Yes, address is not on the EverSafe section. But you should be able to see from the Account Info Section. Go to Profile page, then click the pencil beside your name and you will see it there
or use this link to access :
https://myaccount.publicmobile.ca/en/account/edit/account-info
