e sim
coledelaney02
i have a 15 pro max and when i try to start my e sim its says phone not compatible but im already using one just changed my plan
hi @coledelaney02
iPhone 15 should work.
if you used the PM app and the app said it is incompatible, that is a wrong message.  Please uninstall the PM app first, reboot phone and Reinstall and try again
coledelaney02
yes
umnikke8
The PM app is saying your phone is not compatible with esim?
@coledelaney02
did you use the browser to start the Subscription?  Please use Public Mobile app instead
