06-28-2024
07:08 PM
06-28-2024
09:32 PM
computergeek541
06-28-2024 10:34 PM
It seems the system was down most of the day, if you try now, you should be okay!
06-28-2024 07:30 PM
hi @QUALITYONE
can't receive calls?? new activation with port?? if so, did you get the port authentication text from your old carrier???
06-28-2024 07:27 PM
@QUALITYONE , are you able to select the option of receiving 2FA code to email?
