Phone is activated but nothing works
12-14-2021 10:59 AM - edited 01-04-2022 04:57 AM
I just activated my phone on the 50$ 10gb plan and I'm sending texts but no one gets them. I tried calling and it also tells me that cellular network is not available for voice calls. Does anyone know what's wrong or how to fix this issue?
Joining Public
12-14-2021 09:08 PM
12-14-2021 08:39 PM
@Gflay187 wrote:I just activated my phone on the 50$ 10gb plan and I'm sending texts but no one gets them. I tried calling and it also tells me that cellular network is not available for voice calls. Does anyone know what's wrong or how to fix this issue?
@Gflay187 - do you see Public Mobile at the top of your device? Any network at all showing, or No Service message or something?
Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
Also,
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
12-14-2021 12:25 PM
can you do troubleshoot your device,
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
maybe you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
- you need to send a private message to Customer Support Agent by CS_Agent, by Click Here link.
- please include in your message,
- phone number,
- which carrier,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
- During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
- Note: Public Mobile No Support by phone call or Email.. only by CS_Agent, private message..
- Check your private message inbox (click on the envelope top right of your screen)
Good Luck and your welcome to Public Mobile
you will be very happy...with a Fabulous Service.
12-14-2021 11:35 AM
@Gflay187 activation should be immediate
do you see your phone able to connect to PM network at all?
What kind of phone do you have ? brand/model?
did you try your SIM in another phone?
12-14-2021 11:08 AM
Try rebooting and reset network settings.
Can you try the SIM in another phone? Or at least try reinstalling the card.
If nothing works, your SIM may not be provisioned properly. You'll need to contact CS for help:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
After sending the message, watch your community inbox for their reply.
12-14-2021 11:08 AM
Did you power off the phone before putting in the SIM?
Try powering off the phone then wait a few minutes then power back on the phone.
12-14-2021 11:01 AM
Did you port your phone number over to PM or did you activate just the sim ? Check your account for the status? Try rebooting your phone.
12-14-2021 11:01 AM - edited 12-14-2021 01:08 PM
Porting and activating is not always immediate.
Try:
- rebooting your device,
- resetting network connections,
- toggling airplane mode on and off.
You could also try removing the SIM card and reinserting it.
12-14-2021 11:01 AM - edited 12-14-2021 11:02 AM
What kinda phone you using ? Make sure it's compatible with PM network ?
