09-27-2022
01:01 PM
10-02-2022
11:41 AM
Dunkman
When receiving calls, I can't accept them, after a second they are automatically directed to voicemail.
I have restarted the phone several times, I have a strong network, but it is still not working.
Any help would be appreciated.
I have purchased this phone from PublicMobile in June.
09-27-2022 08:51 PM
@pio28asba wrote:Changing again. It worked once. Now it's not working again.
Are you able to try your SIM card into another phone to test if services are better @pio28asba ?
This would rule out a device issue.
Perhaps check for outages in your area: https://www.telus.com/en/on/outages
09-27-2022 02:46 PM - edited 09-27-2022 02:49 PM
It could be a provisioning issue you can try to fix this yourself by logging into your self serve account go to lost/stolen. Suspend your account... Log out/in. Resume your account services via lost/stolen. Log out and reboot your phone. Try a test call to your phone to see if it's still automatically goes to voicemail.
If you're on the points program you're fine you're on the rewards program you're going to have a glitch so tell us if you are. If this doesn't fix the problem it could still be a provisioning issue and you need customer support or it's a 3G issue. If it's a 3G issue then while on 3G go to in your settings go to About phone then SIM card status then Signal strength. Check what your signal strength is with 3G ideally not below -100dBm.
The Wi-Fi thing is interesting since you got the phone from public mobile and it's quite likely was a telus phone it may have had both VoLTE and Wi-Fi calling enabled on the phone I don't know if VoLTE being enabled on your phone or enabled and disabled has caused an issue but if you have Wi-Fi calling enabled you should be able to call on Wi-Fi so although unusual it can happen with public mobile because it happened to the BF who had a Telus Sonim XP-8 and we discovered he was actually suspended for 4 days but still being able to make calls didn't realize that he was short on his payment. So it could be affecting your phone maybe to its detriment instead of it's betterment but something to consider if nothing else suggested works.
09-27-2022 02:40 PM
@pio28asba wrote:What do you suggest I do ?
Only the carrier can fix a network issue. Unfortunately, that's beyond your control.
09-27-2022 02:39 PM
Check your blocked numbers and your DND settings.
And have you inadvertently set any Call Forwarding features?
09-27-2022 02:37 PM
@softech wrote:(To be honest, you will get better download speed on 3G, just higher latency)
The customer could be on a plan that allows faster LTE speeds. There's also no guarantee of faster speeds on the HSPA+ network than the LTE network with a 3G plan. I've found the HSPA+ network has become heavily congested and it's nowhere near as good as it used to be.
09-27-2022 01:42 PM - edited 09-27-2022 01:43 PM
@pio28asba Leave it on 3G Only for now. You can use voice and data on 3G without issue. (To be honest, you will get better download speed on 3G, just higher latency)
Change it back to the other setting tomorrow and see, if it still not working as well, keep 3G Only for another day
btw, what brand and model is your phone? Try to reseat your sim card once. Power down, then take sim card out for a minute before you put it back and power it up again
09-27-2022 01:40 PM
@mom-in-troubles then you will have to wait for PM support to reply. make sure you check your Community inbox for their reply. If it has been over 24 hours, message them again for update
09-27-2022 01:39 PM
There was another # (##004#) to dial. It's very curious you talking about wifi. That should have exactly nothing to do with not being able to get calls when wifi is on.
Maybe try a restart of the phone. Or maybe even just in and out of airplane mode.
09-27-2022 01:35 PM
09-27-2022 01:33 PM
I dialed #004 and I have removed all do not disturb options. Still not working.
It does work when Wifi is turned off.
09-27-2022 01:25 PM
@pio28asba wrote:I have no trouble with outgoing calls. Only incoming.
Switching to 3G works when Wifi is turned off.
Wi-Fi being on or off wouldn't affect phone calls unless there was out of the ordinary software bug in the device. The reason for setting to 3g workingwould be because of an issue with the phone swtiching from LTE to 3g for phone calls. While this worked, it's not a permanent solution.
09-27-2022 01:24 PM
@pio28asba- Can you go into your dialer and dial ##004#. This resets the call forwarding options to default. It might be where the problem is. Also check the Do Not Disturb option. Is this all callers? Some provider callers?
09-27-2022 01:22 PM
09-27-2022 01:20 PM
I didn’t request a porting, this is a new number
09-27-2022 01:17 PM
Porting is not an issue here since it's a brand new number.
09-27-2022 01:16 PM
09-27-2022 01:14 PM
@pio28asba wrote:it did not work. But thanks
@pio28asba So, 3G Only does not help? When you changed to 3G Only , how many signal bars you have? did you see PM connected?
and can you make outgoing calls when you changed to 3G Only?
Also, try to use your phone in another area, with 3G Only or with the regular LTE/3G settings and see if you are receiving calls
09-27-2022 01:14 PM
I had to set to 3G and restart the phone.
09-27-2022 01:13 PM
@mom-in-troubles wrote:The same issue happen to me, I activated my sim one week ago and I can’t receive calls. If you find the solve can you please tells us. Thank you! I already made a ticket but I don’t have a solve.
@mom-in-troubles you could be a different issue. if you cannot receive incoming calls at all.
Did you request porting? A critical part to porting is to receive a text from your old provider and reply YES within 90 mins. If you are not receiving calls and text on your PM sim card and can only make outgoing calls, then you might have missed the step and hence porting was not completed
09-27-2022 01:12 PM
It was working perfectly fine.
09-27-2022 01:12 PM
09-27-2022 01:11 PM
09-27-2022 01:04 PM
@pio28asba hi I don't believe it's your phone ,try manualy setting your network to 3g see if that helps
09-27-2022 01:04 PM - edited 09-27-2022 01:06 PM
Has this been happening since you got the phone ? If so, start process to have PM replace the phone with a different one.
added..
https://www.publicmobile.ca/en/bc/get-help/articles/phone-warranty-returns-repairs
