12-04-2019 09:01 PM - edited 01-05-2022 08:19 AM
My phone and my wifes phone keep cutting out about 10 minutes into a call any ideas?
12-12-2019 05:15 PM
By reset, do you mean a full factory reset?
12-12-2019 05:14 PM
We both have iphone 7s that were originally on the telus network. No issues with text or data. Last night the calls were getting crackly even when I had 5 bars.
12-05-2019 06:18 PM
If reset doesn't work,use other phone to try, mine Moto did the same thing,must bad antenna.
12-05-2019 12:44 AM
@alexpitt416 wrote:My phone and my wifes phone keep cutting out about 10 minutes into a call any ideas?
That could be anything from bad antenna, weak signal, or account issue the best way is to try your sim in another phone and another Public sim in your phone from a different account.
12-05-2019 12:42 AM
@JJDS wrote:I also had this problem. I have an iPhone 5se. I had to turn off my phone to reset it and the problem tends to go away. Hope that helps.
If it goes away after reset, that sounds like a phone issue. Did you try another phone?
12-04-2019 10:32 PM
12-04-2019 09:06 PM
