07-15-2019 08:34 PM - edited 01-05-2022 08:19 AM
I setted up everything and paid the amount, but when it was activating, it gave me an error and I was still charged but now when I got to log in I can't and when I try activating the SIM again, it talls me the SIM is INVALID. Please help!
07-15-2019 08:52 PM
@hamzasiad don't forget to set up a self serve account if you haven't already
07-15-2019 08:50 PM
Yes my phone is working, Thank you
07-15-2019 08:49 PM
Porting from other mobile companies take a few hours at the most Landlines and VOIP lines can take several days.
You could put your old SIM card into your phone. Once that SIM card stops working, then your port should be completed.
07-15-2019 08:48 PM - edited 07-15-2019 08:49 PM
@hamzasiad i hope that means your phone is working yes porting takes awhile sometimes
07-15-2019 08:47 PM
Cannot recieve calls, guessing porting takes a while? Also thank you
07-15-2019 08:40 PM
Try putting the SIM card in your phone. Sometimes the activation did go through.
If you were charged and the SIM card does not work, do not try activating again since you may be charged again. You may need to contact moderator for assistance.
Send a private message to moderator through the following link :
07-15-2019 08:39 PM
@hamzasiad hi did you check sim in your phone do you have service
