Phone Service Isn’t working
showtimesteph
I recently paid my phone bill which was the student special of 20gb for $55, my service was working for a couple hours but all of a sudden it stopped and i couldn’t make any calls also. I’ve tried removing the sim and putting it back in but that is not working. I also try logging onto pm  which also isn’t working and won’t allow me to create a new password for my account. it currently shows me zero bars for service. can anyone help me with this please
davis946
I think public mobile might not be honouring that deal. I had the same deal but they switched me back to the old plan on my renewal date
@showtimesteph - are you using a 'newer to you' phone? Check if your phone is blacklisted (just to be sure) here: https://www.devicecheck.ca/check-status-device-canada/
Check for outages in your area: https://www.telus.com/en/on/outages
Can you log into your My Account to confirm the account status? My Account is finicky, try accessing it through an incognito mode tab.
Or, If 611 is not working try calling from another phone/landline to # 1-855-478-2542  to check to see what it says when you enter your public mobile phone number.
Was there a disputed charge or anything?
If disabled status and cannot access My Account, submit a ticket to CSA for assistance. To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
darlicious
@showtimesteph
Call 611 from your phone and find out what your account status is? Active or suspended?
If it's suspended do you have any funds in your account balance? $55?
If your account is active do you see public mobile on your phone screen? When you go to your settings in your phone do you see public mobile? Do you have any message like no SIM card detected? Or no network?
What is the make and model of your phone? Are you the original owner?
HALIMACS
@showtimesteph
Try dialing *611.    What messaging is heard?
You might also try:
  1. rebooting phone
  2. swap SIM into another compatible device
  3. reset network connections
EDIT:   also check out your payment card to ensure the payment amount you made is, in fact, displaying as a charge which has settled against the card
