12-24-2022 12:23 PM
I recently switched to public mobile from BellMTS. Since switching over I have not been able to receive text messages from people that are with a certain provider. Everything else has been working great except that. It looks like my number didn't transfer over completely as I never received a text to approve the transfer. I have since lost my old SIM card and only have my public mobile SIM card that is in my phone. There is nothing BellMTS can do about it. Any one know of how I can get my number fully transferred over to public mobile without my old SIM card?
12-24-2022 01:08 PM - edited 12-24-2022 01:11 PM
Beginner mistake if you didn’t reply to the text confirming you are porting over to PM with the old SIM in the phone…you have 90 minutes to reply.
Since you lost your old SIM, looks like you will get a new number.
Try rebooting your phone by powering off the phone then back on with the phone logo showing when powering back on.
The other option is to contact BellMTS and see if you can get your number back if you purchase a new SIM from them and restart the porting process.
12-24-2022 12:30 PM
HI @jls1214 how long you have ported in you number? you can receiving inbound calls?
and you said you cannot receive text from people that are on certain provider, which are the carrier that are on? If you just ported within couple days, it is normal that people from smaller carriers or VoIP might have trouble texting you or calling you. Uusally after 3 day, it will all working well
12-24-2022 12:29 PM
@jls1214 When porting to a new provider , you need to keep your old SIM card in phone to receive a text to confirm the transfer . At that point you have 90 mins to respond YES to the text to port
12-24-2022 12:28 PM
@jls1214 wrote:I recently switched to public mobile from BellMTS. Since switching over I have not been able to receive text messages from people that are with a certain provider. Everything else has been working great except that. It looks like my number didn't transfer over completely as I never received a text to approve the transfer. I have since lost my old SIM card and only have my public mobile SIM card that is in my phone. There is nothing BellMTS can do about it. Any one know of how I can get my number fully transferred over to public mobile without my old SIM card?
Turn off the phone, remove the sim card, wait a couple of minutes, then put in sim card, reboot the phone.
I pm to you porting number, I'm not sure will help, but you can try.
12-24-2022 12:26 PM
@jls1214 important thing is are you receiving incoming calls on your current number?
Try to call again and make sure, this is a critical piece to confirm if your porting was completed
12-24-2022 12:26 PM
If your service is still going with bell contact them for a new sim to your account , and when you get it try to port then , but if you have already cut the service I’m afraid your number is gone for good
