Phone Line
Rahini
Phone line not working
Rahini
Yes, I just tried this on my other phone and it worked! I just needed to call the phone number. Thank you for providing that imformation!
@Rahini there could be issue using *611
try to call 1.855.4PUBLIC from another phone, enter your phone number then.  This is just like using *611 and it should work
And for the phone, power down for 5 mins, then power it up again and see if it works
Also, tell us what is your model and brand of the phone, could be related with VoLTE enablement
Rahini
I can't access my online account information. I true contracting pm about that years ago but didn't work. I see it connected to the network. No error on phone status bar
Rahini
Existing account. I can't receive incoming or outgoing calls or texts. Even *611 isn't working
@Rahini did you try login to My Account to check the account status?  Please login using Incognito mode to confirm the correct account status.
Also, do you see your phone connected to PM network?  Any error showing on the phone status bar on top?
is that just voice call not working? incoming ? outgoing?
how about text? how about data?
Check them and give us more info for us to help
will13am
@Rahini , please provide more information so the community can provide focused suggestions.  Is this a new activation, existing account?  What features are not working?
