01-28-2021 12:18 PM - edited 01-06-2022 01:57 AM
I have two numbers of Public mobile. I just changed my credit card number for the auto pay. How can I know that auto pay is set for both the numbers?
01-28-2021 02:47 PM
@crajibkumar wrote:Can you check my account? The number is 11111111111
edit customers account info ?
01-28-2021 01:18 PM
@crajibkumar wrote:Can you check my account? The number is xxxxxxxxxxxxxx
Almost nobody here can. We're all customers like you.
01-28-2021 12:56 PM - last edited on 01-28-2021 02:49 PM by Luddite
Can you check my account? The number is [private info deleted ...... Luddite]
01-28-2021 12:48 PM - edited 01-28-2021 12:50 PM
@crajibkumar wrote:would you please let me know the steps to create another account for the other number. Thanks.
Upper right of this page click on My Account. On the right side click on Create account. Follow the prompts.
Edit: If you activated this number yourself rather than in store then you would already have done it.
01-28-2021 12:45 PM
01-28-2021 12:32 PM
01-28-2021 12:31 PM
Do you know which number you activate first? Just go to the self-service menu and navigate and create another account with your new number; in this way, you would be able to create a new account for the other number, so you can keep things separate and hassle-free
01-28-2021 12:28 PM
how can I go to each of my account? I have only one account information in self serve. how can I check the other one?
01-28-2021 12:27 PM
Hello,
You must have two profiles; you can change them manually just by signing in to your account.
Go to the Payment tab and change your card number for each account.
Even if you have activated another line from your same account, you need to give a different email to up and running the other phone number.
01-28-2021 12:22 PM
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
01-28-2021 12:20 PM - edited 01-28-2021 12:20 PM
@crajibkumar : you have to go into each account and update them. Then you'll see indications in the self-serve that autopay is set on.
