11-06-2023
11:30 PM
11-07-2023
10:23 AM
Dunkman
My billing cycle with PM auto renews 16th each month
Want to change it to auto renew 26th each month
Without A) Putting service on hold
B) no interruptions to service
Can I do that, and how please?
Thank you ALL in advance
11-14-2023 10:25 AM
Thank you so much
11-07-2023 10:26 AM
As mentioned, the payment cycle is every 30 days. So, the due date changes every month.
I guess that you could just manually pay on the 26th of each month. Not worry about the actual date of renewal.
You could change plans immediately on the 26th also. Note: PM does not pro=rate plans though. Then your due date will be around the 26th going forward depending on which month.
11-06-2023 11:49 PM
First, you payment cycle won't be 16th of each month, it keeps changing.
PM is using a 30 days cycle so cycle starts day will shift up one day after a 31 days month. So, there is no way to fix it to any particular date of the month
