Payment
10-13-2023 12:48 PM
Hi had to pay in order to sign up only to find out AFTER that my phone is not compatible. However, I have already paid, so need someone to get back to me. Thanks
My Account
10-13-2023 05:55 PM
k. Thanks
10-13-2023 02:51 PM
@Sweetbai send a private message to customer support to help you sort it out by clicking here
You will need to monitor your community inbox for a reply (either via the envelope top right or click on your avatar for "messages" if no envelope)
10-13-2023 02:39 PM
I have a redmi/Xiaomi 11 pro and think it's compatible, but on the sign up for an e Sim, I used the IMEI 1 code, and maybe should have used the IMEI 2 code instead. So as a result, I got rejected. So at this point, just want to be able to resign on again with the IMEI 2. However, I have paid already
Thanks for replying
10-13-2023 01:12 PM
Most modern phones are compatible with PM service.
What phone do you have and what SIM did you buy. NOT ALL phones can handle eSIM...
10-13-2023 01:05 PM
@Sweetbai What phone do you have?
10-13-2023 12:51 PM
HI @Sweetbai
your phon enot compatible at all or just not eSIM compatible?
if just eSIM not compatible, you can buy a sim card from Telus or Koodo store and then ask support to change it for you
But if the phone is really not compatible and you try for a refund, please submit a ticket with CS Agent here:
