Payment Voucher
mlyons0705
Payment successfully made.  Account still suspended over an hour later. 😡
9 REPLIES 9
darlicious
@mlyons0705
Did you load the voucher by logging into your self serve account? Check your payment history for the manual top up transaction. (Click the little refresh arrow at the bottom right first) Do you see the transaction? Was the voucher amount enough to pay for your plan?
When paying by voucher it's best to load them via 611 or calling 1 855 4PUBLIC and entering  your 10 digit phone #. Then press(1) and (1) again and enter the 12 digit pin #. You will be told you successfully added funds and you will be automatically reactivated (unless you have suspended via lost/stolen)?
Hi @mlyons0705   call *611 again and confirm how much Available fund you have. If you are sure the voucher is loaded, it's good
You can open ticket with CS agent using message if you have trouble with Chatbot:
If your having trouble with Simone and can’t create a ticket try this direct link
while your already here and logged in the community
  • you can send a private message to our  CS_Agents by clicking here.
@mlyons0705 @You have to keep an eye out on the envelope top of page to the right for response ,, initial response seems to take the longest , but your first reply any back and forth communication is fairly quick and painless also if your able to sign in as @softech  suggested that may be all that needs to be done I assumed you had already tried these suggestions
hairbag1
@mlyons0705
try this...
Also, using your laptop, log in to your account using incognito mode. Clear cache files.
@mlyons0705 wrote:
I cannot successfully create a ticket and sent a pm and no replies.  Really crappy service.
@mlyons0705   then message support directly
but try to reboot the phone once
mlyons0705
@mlyons0705   did you try to reboot your phone?
Also, it is best to login to My Account and see if the money still sitting in Available fund untouched.  If that is the case, click "Reactivate my plan"
if you are unable to login to My Account, open a ticket with PM support and have them to help the login issue as well as reactivate
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
@mlyons0705
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here
