Paying
Tjitske
I cannot login to my account in order to update my payment method
Meow
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
WolverineCaz
I've been in the same situation:
Restart device, try a different browser, make sure to delete cookies (history wouldn't hurt too) and try again. If it still doesn't work, click on forgot password and go from there.
@Tjitske - have you been active with services within the last 90 days? If not, then your account is closed.
If yes, then try a different browser or open a tab in incognito mode, and see if you can log in then.
If having issues with your password, use the Forgot your password option to reset it, found here: https://myaccount.publicmobile.ca/en/forgot-password
If an email is received (check spam/junk folder) then the email is likely registered.
If the account is currently in suspended status you can also look into obtaining a voucher to make a payment through 611,  see here: https://www.publicmobile.ca/en/on/get-help/articles?q=vouchers
Locations to obtain some vouchers found here: https://publicmobile.ca/en/on/payment-voucher
For My Account log in issues, you can submit a ticket here to: Create, forgot or change My Account email or password link
Try again incognito mode private mode there are cache issues , also if your device has stored email pass word allow device to log you in and don’t hit log in
@Tjitske
First try to use the Reset Password link there, enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
Once you get back to the My Account, you can then go to Payment page and update the credit card
