06-20-2023 10:08 AM
i've tried it all. wont work, i need a puk code due to my pin being wrong 3 times. please help
Other
09-12-2023 11:01 PM
@로이스 wrote:puk code
Are you looking for the SIM's PUK code just as the first poster was asking about? If so, please use the instructions provided earlier.
09-12-2023 10:56 PM
puk code
09-05-2023 11:31 PM
I have been using this sim for quite a while it’s a PM sim ….and it’s asking for PUK code not pin …so I private messages CS_agent Soo fingers crossed thank for the reply 👊
09-05-2023 11:12 PM
@Meand wrote:I’ve tied to open ticket 5tines for Puk code and keep getting error code 404 🤷🏻♂️
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
call Samsung 1-800-726-7864 for a master unlock code.
The only info you will need to provide is the IMEI and where the phone was purchased|
open message support there: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
or use this direct link to open Chatbot ticket: https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened. CS Agent will reply to you there.
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier help unlocking it.
(Sorry, for this particular issue, PM support would not be able to help)
09-05-2023 11:08 PM
@blazerdallas please use this direct link to support
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-05-2023 11:08 PM
@Meand- Which puk? What is the exact message the phone is giving you?
If you're getting "SIM network PIN blocked. Enter SIM network PUK." on a Samsung phone then you can call Samsung at 1-800-726-7864 and they will give you a code to unlock it. They'll want the IMEI of the phone in question.
If any of "SIM network unlock PIN", "SIM ME lock code NP", "SIM not Supported", "SIM locked", "Network Unlock Code", "SIM PUK code", "Network Control Key", "Master Unlock Code", "Network PIN" means that the phone is locked to a previous provider. You'll need to contact them to unlock the phone.
If any of "PIN unlock key (PUK)", "Enter PUK Your SIM cannot be accessed", "Locked SIM" then that can be helped by contacting support https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
09-05-2023 11:05 PM
06-20-2023 10:21 AM
@blazerdallas ok, then the support ticket should help. You already opened ticket, right?
06-20-2023 10:20 AM
06-20-2023 10:17 AM
@blazerdallas what was the exact error message?
was the phone ever used on PM network before?
if it never used on PM network before, it likely NOT a sim pin you are looking for , but the carrier unlock PUK, which PM support cannot provide you
You have to ask the carrier where you got the phone from for the carrier unlock code.
(PM would not be able to help with this)
06-20-2023 10:15 AM
tried both. i contacted support, says i need my puk code
06-20-2023 10:14 AM
@blazerdallas how many more attempts?
try 0000 or 1234
but if that does not work, open ticket as advised above
06-20-2023 10:13 AM
sim card pin. i've never set one before
06-20-2023 10:12 AM
@blazerdallas is that a phone unlock PIN or sim card PIN you have entered wrong?
if it is phone unlock PIN, Apple or Google service might be able to help
If it is sim card PIN (those you have setup and need to enter it after ever phone reboot .. NOT after screen lock), then support can help:
open a ticket with PM Support using this direct link: https://urlshortner.tiia.ai/Oyn1L6
06-20-2023 10:11 AM
no links the chat bot gave worked. this one did thank you
06-20-2023 10:09 AM
@blazerdallas Please
Message support directly
- while your already here and logged in the community you can send a private message To CS_Agents click >>>here.<<<
