PUKCode
01-25-2020 10:22 AM - edited 01-05-2022 09:11 AM
Phones
01-25-2020 11:11 PM
threads merged
01-25-2020 11:10 PM
Thanks for the information @computergeek541 .
01-25-2020 11:07 PM
@gblackma wrote:@Husam , The default puk is 1234. If it doesn't work, contact a moderator and explain your situation . Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon . Type moderator and follow the prompts to get to one.
@Husam wrote:I need the PUK Code to unlock my sim
The default PUK of a sim card is never 1234. While the default PIN or a sim card is 1234, that isn't what's being asked for her. The PUK of a sim card is different for every sim card and it's not possible to know it ahead of time unless you get it from the carrier.
01-25-2020 11:33 AM
Since Simon kicked you back to the community @Husam , contact moderator Adriana C directly through this link https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/72993
@Husam wrote:I tried to access to the locked sim account but I could not.
and when I tried to change the password for the locked sim account will change the password for the new sim account because both of them on the same email address!!!
So please I need to unlock the old sim or cancel it or to speak with anyone who can help me!
01-25-2020 11:33 AM
You can't use the same email address for two accounts.
There is no call center for Public mobile. All customer service requests.... need to submit a ticket to get moderator help. It will take a few hours for moderator to respond.
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator. Type: Contact moderator. Follow the prompts to submit ticket.
01-25-2020 11:30 AM
@Husam wrote:The phone is new and it is working now
l bought another BM sim and it's working in the same phone
the problem from the sim
l got new sim with new number , but the old sim, which is locked, still chargers me.
This additional information does help. More details the better.....
If you can't access your self service account for the 1st SIM card, have you tried reseting the password.
https://selfserve.publicmobile.ca/forgot-password/
If that does not work, you will need to contact moderator.
01-25-2020 11:29 AM
01-25-2020 11:18 AM
@Husam @Can you log into the locked SIM account? And remove the autopay credit card
01-25-2020 11:11 AM
01-25-2020 11:03 AM - edited 01-25-2020 11:06 AM
01-25-2020 11:03 AM
@Husam wrote:The sim was working for 20 days then locked.
but it still changes me because of the auto pay
Weird then. Is it possible that your phone got blacklisted? Did you purchase the phone used?
Maybe try the SIM card in another phone. To help determine whether it is a hardware issue versus PM service problem.
01-25-2020 10:58 AM
01-25-2020 10:54 AM
The code 1234 doesn't work
01-25-2020 10:53 AM
Simon tells me to go to community!!!!!
01-25-2020 10:46 AM
@Husam . You can also try the 1234 pm default puk. Or contact the manufacturer to unlock the phone. Or if it all fails, contact a moderator and explain your situation . Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon. Type moderator and follow the prompts to get to one.
01-25-2020 10:42 AM
Chances are you need to contact your previous provider or manufacturer to give you the code, they must do it free of charge. Chances are it's your phone, public doesn't lock the sims.
Don't try too many times as you can permanently lock the device
01-25-2020 10:42 AM
You should remove your phone# as this is a public forum. Click on the three dots to edit yur post.
01-25-2020 10:42 AM
Please remove your phone number from this public forum.
Assuming you are new customer and your phone has not worked with PM before, it sounds like that your phone is locked to previous carrier. You may need to contact your previous carrier and get this unlock code.
01-25-2020 10:40 AM - edited 01-25-2020 10:42 AM
@Husam please remove your phone number from the post by clicking on the 3 dots on the top left of the post.
01-25-2020 10:38 AM - edited 01-25-2020 10:43 AM
When I try to call anyone
Enter PUK
Your sim cannot be accessed. Pleas call your carrier to obtain your Puk code
my Phone is IPhone 7 plus
01-25-2020 10:30 AM
01-25-2020 10:28 AM - edited 01-25-2020 10:29 AM
This is a duplicate post. You have already posted this question to the forum.
01-25-2020 10:26 AM
01-25-2020 10:25 AM
What is the exact message being shown? There are different versions of this code. Also, what is the circumstances around being asked for this code? New customer? New phone? Which model phone?
Sometimes your phone is locked to previous carrier and you will need to contact previous carrier for this code. Other times, you will need to contact Public mobile moderator for this code.
01-25-2020 10:25 AM
Here is a previous thread with more info. https://productioncommunity.publicmobile.ca/t5/Getting-Started/PUK-Code/m-p/423240
