07-24-2019 09:39 AM - edited 01-05-2022 06:04 AM
07-24-2019 11:20 AM
No. Public Mobile only works in Canada and the U.S.. You will need to purchase a prepaid SIM in the country you will be travelling to.
07-24-2019 09:46 AM
PM doesn't offer direct service outside of Canada and the U.S.
My suggestion would be to get a prepaid sim card when you get to the airport in the target country.
07-24-2019 09:45 AM
With all public mobile plans, no international roaming except for USA, where you have to buy 10 day data roaming packages.
07-24-2019 09:44 AM
PM does not offer roaming except in the US. You could either buy a local sim or use one from Gigsky. If you have access to wi-fi then you could use apps like Skype, Fongo, or Textnow.
07-24-2019 09:41 AM
As in outside of US/Canada. No, it does not. You'd need to make arrangements for a prepaid sim or rely on an app like Fongo or TextMe on WiFi to do calls/texts.
