PIN NUMBER
MARGENIS
I NEED A PIN NUMBER
cellphoneuser1
@MARGENIS wrote:
I NEED A PIN NUMBER
Do you mean a voucher PIN?  Those can be purcahsed from stores like Shoppers Drug Mart or from recharge.com.
@MARGENIS
you can set or update your account pin here
https://myaccount.publicmobile.ca/en/account/reset/pin
hi @MARGENIS do you see the PIn option on your My Account -> Profile section? you can update it there
@MARGENIS  You can create and make your 4 digit PIN here
Pin Public Mobile - My Account
