2 weeks ago - last edited 2 weeks ago by computergeek541
I swtiched from Koodo Prepaid. Something in the transfer went wrong... On my online Public Mobile account it says my phone number is my old Koodo number. My Koodo account is closed. But on my phone, I have a new number showing as my phone number and my old number also as a phone number. I can't seem to figure out how to change this so I only have my phone number that I have had for years... Ideas? Also I can't log in on the Public App because it is trying to send a text to this new number and I am not getting it...
2 weeks ago
Don't need a call centre... just need someone that actually knows how to fix issues. It literally took me 2 seconds once I found the problems. Problems that I feel Public Mobile should have been able to trouble shoot. Especially the 2 step verification. I could see maybe a technician doesn't know iPhones or something... Anyone who is reading this though has already taken the plunge of the deep end... LOL. Hopefully this post will help someone else in the future.
2 weeks ago
@KerryK wrote:I fixed my phone by updating my phone number manually in my iPhone in settings under phone, my number. It had the temporary number there. I changed it to my old number and it works now. Then to fix the log in on the app. I was able to change the text code being sent to the wrong number by going to Manage Eversafe ID. Good luck with this company if you aren't good with technology... I have had several messages back and forth and figured this out on my own.. They were not helpful at all.
All are welcome but Public Mobile really is for people who are good with technology. Telus offers other brands for customers who need tradiional call centre service.
2 weeks ago
2 weeks ago
I have done that already but I just saw that I can manually type in a phone number under Phone, My Number. I typed my old number in and saved it. This seems to have worked... However, I still can not log into Public Mobile as the text goes to the new number that was created.
2 weeks ago
hi @KerryK
when inbound calls come, does your phone with PM sim card ring? if it is , the porting is completed
And you are using iPhone? The phone number showing the incorrect one is an iPhone thing. Usually it would be gone if you remove the old sim card , then Reboot the phone and Reset Networks Settings on the phone
2 weeks ago
It was active and I did get the help to port number. On my online account with Public Mobile I was logged in on my laptop and can see my old phone number is on there. But on my phone it is the new number. And... I can not log into Public on my phone because its trying to send a text to the new number... So if I accidentally log out of public mobile I can't get back in. Trying to chat with Help but its hours between messages.
2 weeks ago
hi @KerryK
for porting from Koodo prepaid, you need to ask support agent to help to port. Did you ask them?
and usually the "from" account should be active, but it is ok if the account is suspended if you are porting from Koodo
I think you should ask support agent to check and help. You can submit by direct message:
