09-30-2021 01:56 AM - edited 01-06-2022 03:27 AM
Good day I would like to know how do I go about using public mobile services in the states (NY). How can I activate this service. Also I have 499 international minutes available to me but I don't know how to get access to it. Can someone please help me.
P.S I don't come here often, baby steps please
10-01-2021 12:57 PM - edited 10-01-2021 12:58 PM
Lucky doesn't have roaming anywhere in the world.. Their subscribers not lucky, they can't even roam in USA
@Ladda , If you just need to call back Canada, consider using app like Fongo or TextNow. They are both free and easy to setup. You can use it as long as you have Wifi
If you are there long and need Data as well, check to get local Prepaid SIM. It's definitely cheaper than using roaming
10-01-2021 12:52 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
and can you try manually selecting network,
*To get the obvious out of the way...you used ( +1 or 1 ) in front of the any area code,
for Example long distance, Add (+1 or 1 ) in front of the any area code,
1416xxxxxxx,
or
+1416xxxxxxx,
both is will going through your call...
Good luck and enjoy the service
10-01-2021 07:18 AM
Here is more or less everything you need to know about US roaming add one...
Here is some info about US roaming add ons that should help you.....
09-30-2021 11:24 AM
@Meow : I meant the $20 bundle when I said bundle.
09-30-2021 10:56 AM
@Anonymous wrote:So a bit of a difference from $2 a day for the bundle here. No pay as you go though of course.
Thank you for bringing these prices to my attention. Considering your list, then PM's $8/10 days (talk ot SMS) is very good deal for unlimited talk/text. $0.80/day or calls and SMS for $1.5/day.
I do not get this $2/day??
09-30-2021 10:40 AM
@Meow wrote:Using PM from USA will not be very cost effective. As you can see per above post USA add-ons are for limited time only and costly. But depending on your needs they might work...
You are better to get some temporary USA SIM with unlimited calls/SMS to Canada.
Your PM international minutes add-on work from Canada only.
@Meow :
I don't know about expensive. Short duration yes but not all that expensive.
Chatr has pay as you go so that could add up fast.
Lucky doesn't mention roaming.
Koodo is $9 a day and offers pay as you go.
Virgin is $10 a day and offers pay as you go.
Fido is $15 a day and offers pay as you go.
And the above cap at a certain total.
09-30-2021 10:38 AM
09-30-2021 10:16 AM
09-30-2021 02:27 AM
To use your phone in the USA you need to buy a USA add-on
The add-on is valid for 10 days then needs to be repurchased .
U.S. Talk, Text and 250 MB Data bundle: $20
U.S. Talk and Text Bundle: $15
U.S. Talk Only: $8
U.S. Text Only: $8
250 MB: $10
500 MB: $15
1 GB: $20
09-30-2021 02:25 AM
@Ladda wrote:Good day I would like to know how do I go about using public mobile services in the states (NY). How can I activate this service. Also I have 499 international minutes available to me but I don't know how to get access to it. Can someone please help me.
The long distance minutes won't help you. Those will only work while you are in Canada.
Your need to log into your Self Serve account at https://selfserve.publicmobile.ca and purchase a roaming add-on. After logging in, Click on "Purchase Add-ons". Ensure you choose one of the options that start with the name of "US Roaming" as none of the others will help you to use your service in the U.S.
You should know tha during this process, you'll want to check above the add-on selection box where it says "available funds". If you go through these steps to choose an add-on but don't have enough in your available funds to pay for the add-on, this process will only top up your account, and you'll need to go back a second time to actually purchase the roaming add-on pacakge.
