Outbound phone calls doesn't ring the first time
supermoon
Hi, I migrated back to Public Mobile from Koodo on the $40/15gb plan a few weeks ago. However, when I make a phone call, it does not ring through, all I hear is silence. If I hang up, then redial, it will ring through, I'll hear the dialing sounds. This happens with calling my VM too. I did not have any issues like this when I was on Koodo, even though it's the same network. I've tried restarting my phone.
Does anyone else have this issue? Is there a fix?
supermoon
Thanks hTideGnow for all the ideas, I'll give them a try!
HI @supermoon   did you get this weird voice problem everywhere?  Try in different area and try to call different number
You can change network type to 3G ONLY and see if it helps, I think it will.  But I won't suggest you to leave it as 3G Only as you are on 4G speed data plan.  Just change for a test and change it back
You should also try Reset All network after and it might resolve your problem
supermoon
Hi @will13am , thanks for the reply. I'm using Samsung S22. It's the same phone I used while on Koodo.
will13am
@supermoon , maybe it is a phone issue?  What model of phone are you using?
