Outage
09-07-2023 08:37 AM
I am not able to make calls it says I am calling the US and do not have a US plan . Will not allow me to log in on my device ! What is the problem ? 5G?
Service
09-07-2023 10:29 AM
All of your outgoing calls? Or just one recipient? That message seems to be indicating that either your account or the recipient account are suspended.
09-07-2023 10:27 AM
are you "close" to a US border ? When I drive through parts of BC near the border, such as Grand Forks...I get similar message as you. For me, it'll clear up momentarily after driving a mile or so. It also happened to me while driving in Victoria BC and Windsor Ont. My phone is set to Automatic Network selection and the US signal can be stronger than Cdn at times. You can turn off Auotmatic selection and manually select PM...OR...move around a bit to get the correct Cdn PM signal again. You won't be charged any roaming costs...there are no roaming costs with PM.
09-07-2023 10:05 AM
Hi @Wenfra11
That has been a common problem for several public mobile customers. Nobody knows why that's been happening. The only suggestion that I can make is to go into your network settings and reset them. Then reboot. If that doesn't help, I'd suggest putting in a ticket to a CS Agent to advise them of the problem. The more people who complain about this issue, maybe they may start fixing it.
09-07-2023 08:49 AM - edited 09-07-2023 10:06 AM
@Wenfra11 check
Outage map in your area:
https://istheservicedowncanada.com/
also can you dial *611 and confirm if your account is active or on hold . If on hold you need to make manual payment to resume services
