Outage?
I_am_oasis
Not getting anything more than H+ at the moment. Any known outages in the Manitoba area?
15 REPLIES 15
bbbbn
It is now back to 5G (with working data)
bbbbn
Three people now.
bbbbn
Is it enough for you to access the web and emisl?
Whenever I get 3G, it usually means Telus/Public Mobile are having issues
hi @I_am_oasis
yes, we have another member also in Winnipeg has the same issue
Try changing the network mode to 3G and hope it works for now
Knarf_c
I’m currently only getting 3G on my iPhone 13 in Winnipeg, whereas I normally get 5G.
I_am_oasis
Winnipeg
bbbbn
metro/ capital region. Whenever it connects with 3g, websites won’t load. It’s fast enough to connect  to a vpn, so I know it’s technically tx/rx data, but effectively there is no connection.
I can’t try changing sim cards etc right now.
hi @bbbbn  data should work on 3G as well.
and which area you are at?
bbbbn
Same here. iphone 15. It says 3G, which means no data. Calls work, and text seems to work.
I_am_oasis
My apologies. What I meant to say was if I put the PM sim in my S21, I see LTE but still no data capability.
I_am_oasis
So it appears it might be the sim card? Or my account?
I took the PM sim and put it in my s21. LTE. I took the s21 Bell MTS sim card and put it in my Pixel 7. 5g. So I know it's not the pixel 7 hardware but something to do with the sim and the phone combined?
hi @I_am_oasis
what phone  do you have?
and you have another phone to test the sim card as well?
I_am_oasis
I also have preferred network type set to 5G. No recent updates. No recent installs of 3rd party software.
5G was working yesterday.
I_am_oasis
Pixel 7.
I tried to restart the phone. No resolution. I turned off phone, pulled the sim for 20 mins and put it back in and turned on phone. Same issue. Only shows H+ in the top right hand of screen but no data. I'm able to receive text messages.
hi @I_am_oasis
there is no outage in Manitoba at this moment.
it has a degrade service alert for "Eastern Canada", but I doubt MB is part of that alert
https://www.telus.com/en/mb/outages
