11-04-2023 08:13 AM - last edited on 12-25-2023 01:02 PM by computergeek541
Hi, I am looking at the change subscriptions options and can only select the two lowest options. This is the same when I am logged in on the mobile app. There is no option to change between 'ALL', '5G Speed','4G Speed', '3G Speed' like on the plans page (https://www.publicmobile.ca/en/nl/plans#ALL). Can someone look into this or tell me how to fix this?
12-25-2023 12:33 PM
HI @John_Bee
what did you not see?
can you post us a screenshot of what you have and we can help further
12-25-2023 12:28 PM
None of that works, it does not work in the browsers or the app.
11-04-2023 08:26 AM
@RyanLau You're not the only one to have this problem. Maybe send a private message to support for assistance using this link
You'll need to watch the envelope icon top right for a reply, or select your avatar for a drop down menu and "Messages"
11-04-2023 08:24 AM
I've tried sliding it, and it does not work, it functions like a button. (same on the mobile app).
11-04-2023 08:24 AM
I've tried both suggestions of using incognito and reinstalling the mobile app, and neither changed anything.
11-04-2023 08:17 AM
@RyanLau Does that "all" button slide along to the right? It looks like it should.
11-04-2023 08:15 AM
@RyanLau Maybe try uninstalling the app and re installing it see if that helps or if on computer try again incognito private mode and clear web browser cache and cookies and see if that makes any difference for you .
