12-24-2023
08:59 AM
12-24-2023
04:34 PM
computergeek541
Hi there!
I just helped 2 of my friends to subscribe to a plan with PM. My question is, will I get the rewards the same month they activate the plan? or later on? To make sure when I should make a follow-up.
Thanks
12-25-2023 12:37 PM
thanks for the update @Jedi1 , Happy Holiday!!
12-25-2023 12:36 PM
@hTideGnow Just to update, my referral points are showing this morning.
12-24-2023 04:57 PM
@hTideGnow Thanks, unfortunately new points system, but it still makes a difference for us as I pay for 5 lines. My son referred me and he got his point yesterday on his renewal. The rest of us renew tomorrow.
12-24-2023 04:00 PM
hi @Jedi1 the Cha Ching text is hit or miss, does not come all the time , but you should get 3 referrals rewards yourself, $3 or 3 points
Are you on legacy or new rewards system? Check My Rewards site and you should see an increase in referrals. If not, please check with PM CS agent
12-24-2023 03:50 PM
@hairbag1 I referred 3 family members last month but only got the cha Ching once although they all got their $10 and they were all on the same day. Should I have got it for each one? I am hoping mine updated correctly. I guess we will find out tomorrow when my plan renews.
12-24-2023 10:13 AM - edited 12-24-2023 10:14 AM
so long as your renewal is not within 48 or so hours of their activations, you will see the credits on your next renewal for both referrals, providing they entered your referral code correctly.
12-24-2023 10:00 AM
@yen wrote:They ordered the SIM card but activation will be made in January just before their other plans are finished. So that means, after they activate I will be able to see my rewards, am I right?
Correct. Once they successfully activate their new PM account using your referral code, you should get a text message CHA*CHING from PM telling you the good news.
12-24-2023 09:59 AM
@yen , I don’t know. I am on the points program so I don’t get mine until after my plan renews. @Handy1 is on the old rewards so he would know.
12-24-2023 09:53 AM
12-24-2023 09:44 AM
rewards
12-24-2023 09:32 AM
are you on the Rewards program or did you change to Points ? ? Don't ever opt out of Rewards voluntarily.
12-24-2023 09:30 AM - edited 12-24-2023 09:30 AM
@Handy1 wrote:@yen You should see it show up right away but could take up to 3 days and you earn
the reward every 30 days that they say with PM
@Handy1 , if that person is on old rewards ($) & not points (point)! I am on points & I do not receive them until after I pay my bill (plan renews). I have to accumulate 15 points before I can even redeem them to use towards my bill!
12-24-2023 09:25 AM
